Hello,
Since the recent updates I wanted to use syncthing-inotify delay-scan options but it doesn’t seems to work:
$ ./syncthing-inotify -delay-scan="86400" -api="XXXXXXX"
[OK] 10:26:56 Watching zukoo_perso: /home/zukoo/zukoo_perso
[OK] 10:26:56 The rescan interval of folder ISOs can be increased to 3600 (an hour) or even 86400 (a day) as changes should be observed immediately while syncthing-inotify is running.
If i look at the webUI the folders status change to “Scanning” every minutes or so. Is there anything else to do in syncthing config file for exemple?
FX
