Syncthing-gtk startup on window mode in i3wm
Hi, i’ve discovered that on my i3wm session, syncthing-gtk starts always on window mode, even if i set the minimized startup option in settings, or if i try to run with this command in my .i3/config file.
exec --no-startup-id syncthing-gtk -m
What is strange is that on an active i3 session, syncthing-gtk starts always minimized instead, so it’s just a issue regarding the startup phase of the WM.
Thanks for your support. Marco
Ping @kozec.
You might get a better response if you raise an issue on the Syncthing-GTK bug tracker: https://github.com/syncthing/syncthing-gtk/issues/new
