I need syncthing to work on my universities’ internet (eduroam) but it doesn’t work for some reason.
I need my laptop to sync with my raspberry pi when I’m outside lan (and when I’m in lan as well). In the web-gui, when I was connected to my univ’s IP, it said that the connection type was via “relay client”, but nothing synced.
Is there a way to make it so it works outside lan?
You might setup an OpenVPN Server on your raspberry and tunnel the traffic from your laptop to the Pi. I have a similar setup as I didn’t want to use NAT and discovery features
Yes, it’s pretty easy. You’ll need a dedicated server with a permanent internet connection, decent bandwidth (symmetric, both up and down), and a decent data limit (in the region of 1TB/month plus).
