I am using 0.12 version at two devices (both win 7 64bit). They sync OK but after 10-15 minutes I received this message "connection to XXXX-XXXX… closed: read time out" and the sync is broken ¿Any idea or solution? Thank you.
If its a temporary outage it will try to reconnect. Also, post a screenshot of the device overview expanded while they are connected.
