Hello, a few minutes ago I noticed some unexpected network connections from my computer. netstat -p tells me that Syncthing is connecting to some seemingly random address (cetus.h.sum7.eu:22067), which resets connection if I try to curl it. sum7.eu seems to be a German hosting company. Is this expected? I cannot find references to the said doman name (neither bare domain not fqdn) in the Syncthing sources or issues (github search).
I have not configured synthing to make non-local connections, and because I use it from the Debian repo, it can not self-update.
Is it not possible to run Syncthing reliable w/o global discover and relay? Reading the spec on Relay v1 paragraph 4.4.7, I gather that data is transmitted through a third party, which is highly undesirable for me, regardless of the details of encryption used.
You can disable both discovery and relay in Syncthing settings.
I am not even using local discovery in my setup. As long as you have at least one computer in each pair with a fixed IP address, you can just configure Syncthing on the other to connect to it. Of course, the connecting computer should be able to establish a TCP connection to the port Syncthing is listening to, so check firewalls etc.
