Syncthing blocked from synching
I have one folder to be synched with another pc, and are three days that syncthing is blocked at 96%
I tried to reset both databases at the same time (--reset-database) and then restart both but it did not change.
Is there a way to force finishing synching ?
Thanks
Please post screenshots of the GUI from both sides.
The two Folders are up to date on 840-G6, and not on Deskt, and it looks like nothing is being sent. Are both of these Folders Send Only? And what do you mean by “mirror”?
It’s going to be tough for me to help figure out why items are out of sync from what you’re showing. Is there anything that stands out among the 160 items out of sync? Are they in one or both Folders? Anything in the log, particularly on Deskt, to indicate what’s happening?
Only the folder “Backup 840-G6” contains data The folder “Default” is empty
The folder “Backup 840-G6” is a send-only The item to be synched are in this folder
The logs in both pcs does not contains errors or warnings
Here are the receiver last two days log
[start] 2025/04/08 21:02:16 INFO: syncthing v1.29.4 "Gold Grasshopper" (go1.24.1 linux-amd64) [debian@github.syncthing.net](mailto:debian@github.syncthing.net) 2025-03-27 09:31:51 UTC [noupgrade]
[XXXXX] 2025/04/08 21:02:16 INFO: My ID: XXXXXXXXXXXXXXX
[XXXXX] 2025/04/08 21:02:16 INFO: Hashing performance is 330.78 MB/s
[XXXXX] 2025/04/08 21:02:16 INFO: Overall send rate is unlimited, receive rate is unlimited
[XXXXX] 2025/04/08 21:02:16 INFO: TCP listener ([::]:port) starting
[XXXXX] 2025/04/08 21:02:16 INFO: Detected 0 NAT services
[XXXXX] 2025/04/08 21:02:16 INFO: Using discovery mechanism: global discovery server https://discovery-lookup.syncthing.net/v2/?noannounce
[XXXXX] 2025/04/08 21:02:16 INFO: Using discovery mechanism: global discovery server https://discovery-announce-v4.syncthing.net/v2/?nolookup
[XXXXX] 2025/04/08 21:02:16 INFO: Using discovery mechanism: global discovery server https://discovery-announce-v6.syncthing.net/v2/?nolookup
[XXXXX] 2025/04/08 21:02:16 INFO: Using discovery mechanism: IPv4 local broadcast discovery on port 21027
[XXXXX] 2025/04/08 21:02:16 INFO: Using discovery mechanism: IPv6 local multicast discovery on address [ff12::port]:21027
[XXXXX] 2025/04/08 21:02:16 INFO: GUI and API listening on 127.0.0.1:XXXX
[XXXXX] 2025/04/08 21:02:16 INFO: Access the GUI via the following URL: http://127.0.0.1:XXXX/
[XXXXX] 2025/04/08 21:02:16 INFO: My name is "receiver-host"
[XXXXX] 2025/04/08 21:02:16 INFO: Device XXXXXXXXXXXXXXXX is "send_only-host" at [dynamic]
[XXXXX] 2025/04/08 21:02:16 INFO: Ready to synchronize "Default Folder" (default) (sendreceive)
[XXXXX] 2025/04/08 21:02:16 INFO: Ready to synchronize "Backup send_only-host" (xxxxx-xxxxx) (receiveonly)
[XXXXX] 2025/04/08 21:02:16 INFO: Completed initial scan of sendreceive folder "Default Folder" (default)
[XXXXX] 2025/04/08 21:02:17 INFO: Completed initial scan of receiveonly folder "Backup send_only-host" (xxxxx-xxxxx)
[XXXXX] 2025/04/08 19:04:43 INFO: Established secure connection to send-host at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/08 19:04:43 INFO: Device send-host client is "syncthing v1.29.4" named "send_only-host" at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/08 19:29:44 INFO: Lost primary connection to send-host at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx: read timeout (0 remain)
[XXXXX] 2025/04/08 19:29:44 INFO: Connection to send-host at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx closed: read timeout
[XXXXX] 2025/04/08 19:31:57 INFO: Established secure connection to send-host at [ipv6-send-host]:port-[ipv6-receiver-host]:port/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/08 19:31:57 INFO: Device send-host client is "syncthing v1.29.4" named "send_only-host" at [ipv6-send-host]:port-[ipv6-receiver-host]:port/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/08 19:32:17 INFO: Sent usage report (version 3)
[XXXXX] 2025/04/08 19:32:46 INFO: New external port opened: external TCP address(es) [ipv4:62054] to local address [::]:port.
[XXXXX] 2025/04/08 19:41:57 INFO: Lost primary connection to send-host at [ipv6-send-host]:port-[ipv6-receiver-host]:port/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx: Syncthing is being stopped (0 remain)
[XXXXX] 2025/04/08 19:41:57 INFO: Connection to send-host at [ipv6-send-host]:port-[ipv6-receiver-host]:port/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx closed: Syncthing is being stopped
[XXXXX] 2025/04/08 19:41:57 INFO: TCP listener ([::]:port) shutting down
[XXXXX] 2025/04/08 19:41:57 INFO: Exiting
[start] 2025/04/09 18:24:21 INFO: syncthing v1.29.4 "Gold Grasshopper" (go1.24.1 linux-amd64) [debian@github.syncthing.net](mailto:debian@github.syncthing.net) 2025-03-27 09:31:51 UTC [noupgrade]
[XXXXX] 2025/04/09 18:24:21 INFO: My ID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/09 18:24:21 INFO: Hashing performance is 344.55 MB/s
[XXXXX] 2025/04/09 18:24:21 INFO: Overall send rate is unlimited, receive rate is unlimited
[XXXXX] 2025/04/09 18:24:21 INFO: TCP listener ([::]:port) starting
[XXXXX] 2025/04/09 18:24:21 INFO: Using discovery mechanism: global discovery server https://discovery-lookup.syncthing.net/v2/?noannounce
[XXXXX] 2025/04/09 18:24:21 INFO: Using discovery mechanism: global discovery server https://discovery-announce-v4.syncthing.net/v2/?nolookup
[XXXXX] 2025/04/09 18:24:21 INFO: Using discovery mechanism: global discovery server https://discovery-announce-v6.syncthing.net/v2/?nolookup
[XXXXX] 2025/04/09 18:24:21 INFO: Using discovery mechanism: IPv4 local broadcast discovery on port 21027
[XXXXX] 2025/04/09 18:24:21 INFO: Using discovery mechanism: IPv6 local multicast discovery on address [ff12::port]:21027
[XXXXX] 2025/04/09 18:24:21 INFO: Ready to synchronize "Default Folder" (default) (sendreceive)
[XXXXX] 2025/04/09 18:24:21 INFO: Detected 0 NAT services
[XXXXX] 2025/04/09 18:24:21 INFO: GUI and API listening on 127.0.0.1:port
[XXXXX] 2025/04/09 18:24:21 INFO: Access the GUI via the following URL: http://127.0.0.1:port/
[XXXXX] 2025/04/09 18:24:21 INFO: My name is "receiver-host"
[XXXXX] 2025/04/09 18:24:21 INFO: Device send-host-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx is "send_only-host" at [dynamic]
[XXXXX] 2025/04/09 18:24:21 INFO: Ready to synchronize "Backup send_only-host" (xxxxx-xxxxx) (receiveonly)
[XXXXX] 2025/04/09 18:24:21 INFO: Completed initial scan of sendreceive folder "Default Folder" (default)
[XXXXX] 2025/04/09 18:24:22 INFO: Completed initial scan of receiveonly folder "Backup send_only-host" (xxxxx-xxxxx)
[XXXXX] 2025/04/09 18:25:33 INFO: Established secure connection to send-host at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxx-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/09 18:25:33 INFO: Device send-host client is "syncthing v1.29.4" named "send_only-host" at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxx-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/09 18:54:23 INFO: Sent usage report (version 3)
[XXXXX] 2025/04/09 18:54:52 INFO: New external port opened: external TCP address(es) [ipv4:62054] to local address [::]:port.
[XXXXX] 2025/04/09 19:29:16 INFO: Lost primary connection to send-host at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxx-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx: reading length: read tcp xxx.xxx.xxx.xxx:xxxx->xxx.xxx.xxx.xxx:xxxx: read: connection reset by peer (0 remain)
[XXXXX] 2025/04/09 19:29:16 INFO: Connection to send-host at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxx-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx closed: reading length: read tcp xxx.xxx.xxx.xxx:xxxx->xxx.xxx.xxx.xxx:xxxx: read: connection reset by peer
[XXXXX] 2025/04/09 19:34:52 INFO: Established secure connection to send-host at [ipv6-send_host]:port-[ipv6-receiver_host]:port/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/09 19:34:52 INFO: Device send-host client is "syncthing v1.29.4" named "send_only-host" at [ipv6-send_host]:port-[ipv6-receiver_host]:port/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/09 22:07:23 INFO: Lost primary connection to send-host at [ipv6-send_host]:port-[ipv6-receiver_host]:port/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx: reading length: read tcp [ipv6-send_host]:port->[ipv6-receiver_host]:port: read: connection reset by peer (0 remain)
[XXXXX] 2025/04/09 22:07:23 INFO: Connection to send-host at [ipv6-send_host]:port-[ipv6-receiver_host]:port/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx closed: reading length: read tcp [ipv6-send_host]:port->[ipv6-receiver_host]:port: read: connection reset by peer
[XXXXX] 2025/04/09 22:07:23 INFO: Established secure connection to send-host at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxx-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/09 22:07:23 INFO: Device send-host client is "syncthing v1.29.4" named "send_only-host" at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxx-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[XXXXX] 2025/04/09 22:40:08 INFO: Lost primary connection to send-host at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxx-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx: Syncthing is being stopped (0 remain)
[XXXXX] 2025/04/09 22:40:08 INFO: Connection to send-host at xxx.xxx.xxx.xxx:xxxx-xxx.xxx.xxx.xxx:xxxx/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-xxx-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx closed: Syncthing is being stopped
[XXXXX] 2025/04/09 22:40:08 INFO: TCP listener ([::]:port) shutting down
There’s very little to go on here. Please configure Syncthing on both sides to use the model and scanner log facilities (Debugging Syncthing — Syncthing documentation), and restart Syncthing on both sides. Let it run for a bit and show us the log from that, please.
resetted both deltas, restarted both, resetted both database, restarted both, now both are up to date
