Akkor70
(Akkor70)
May 23, 2020, 10:49pm
21
I found this
root@ubuntu:/# syncthing -paths
Configuration file:
/root/.config/syncthing/config.xml
Database directory:
/root/.config/syncthing/index-v0.14.0.db
Device private key & certificate files:
/root/.config/syncthing/key.pem
/root/.config/syncthing/cert.pem
HTTPS private key & certificate files:
/root/.config/syncthing/https-key.pem
/root/.config/syncthing/https-cert.pem
Log file:
GUI override directory:
/root/.config/syncthing/gui
Default sync folder directory:
/root/Sync
In /root/.config/syncthing/gui ther’s no gui folder
How to enable a log to /var/log/ path ?
I am not sure why you think this is relevant.
The GUI directory is a override directory, if you want to use a custom UI.
means it logs to stdout, so the logs are probably captured by your service manager.
You can specify -logfile command line option to whatever starts syncthing, but I am not sure you know what that is by the looks of it.
wweich
May 24, 2020, 8:37am
23
You service file starts syncthing like this, so the gui address is overritten and the config is ignored:
/usr/bin/syncthing -no-browser -gui-address=192.168.1.10:8384 -no-restart -logflags=0
system
(system)
Closed
June 23, 2020, 8:37am
24
