I’ve just managed to get SyncThing work with my Windows 10 PC, my Windows 10 Laptop and my phone and primarily use it to sync my whole music database (about 60GB).
Syncing with my phone works fine, but right now I’m trying to get something work with my PC and Laptop. Here’s the issue:
I’m using my PC (let’s call it A for now) for my primary music database and use my Laptop (B) for DJing purposes (using Traktor v3.2.0). That means I want to transfer songs from A to B and have the changes I made in B transfer back to A and so on depending on what I want to change (metadata on A or B for organizing purposes, global gain settings etc).
Right now I set my A as master and read-only and my B to write-only, but as soon as I set both to read and write I get many sync-errors on A and B and it eats up my disk space. Any possibilities how to set it up properly?
Yes they are edited by some bits because I load them up in Traktor for editing e.g. cue points and Traktor saves this information in the file… I only want the edited files from B to be transferred to A (overwriting them if possible) so that these files are all in sync.
