esingress
(Es Ingress)
June 22, 2021, 7:43am
#1
Syncthing ersion: v1.13.1, FreeBSD (64-bit Intel/AMD)
I setup a Syncthing in FreeBSD jail.
When I try to Sync files, it seems can transfer to the Server, but it cannot finalize the file
After Sync fail, use ls -sl the /mnt/Server01, it shows
root@Syncthing:/mnt/Server01 # ls -sl
total 79
16 drwxrwx— 1 syncthing syncthing 16384 Jun 22 14:25 .stfolder
31 -rwxrwx— 1 syncthing syncthing 31554 Jun 22 13:39 .syncthing.test.pdf.tmp
16 drwxrwx— 1 syncthing syncthing 16384 Jun 22 13:39 Print
16 drwxrwx— 1 syncthing syncthing 16384 Jun 22 13:39 test
Any Hints? Thanks!
We just resurface the error we got from the operating system.
I guess try running it outside of the jail.
esingress
(Es Ingress)
June 23, 2021, 4:48am
#3
OK. Maybe I found the problem.
On the Server01 smb,
I add a line in smb.conf
share modes = no
I don’t know it is the problem cause the Syncthing not work or it make the FreeBSD server cannot mount the remote smb Server properly.
But at least, the problem seems to be solved now.
Thanks again.
system
(system)
closed
July 23, 2021, 4:49am
#4
