All devices syncing to my android say synced 91%. All the resetting, rebooting, & cussing I try won’t get this thing to finish syncing. It seems to be the same regardless of send-only, or not.
I did see an error something about marker, I think, but I can no longer find that error message.
What now?
Incomplete percentages usually mean one of these things:
- Not all folders are shared both ways.
For example A shares X and Y with B, and B only shares X with A, which causes A to see B out of sync as all files from Y are missing.
- Completion percentage is affected by ignore files.
- A is a send only folder, yet B has modified files that A is refusing to accept (as it’s send only) which makes A look uncomplete percentage on B, and A out of sync on itself.
- Some files fail to sync, which should show failed items somewhere.
