As long as the shutdown was clean and not some kind of a hard reset or such, I would say that you should not worry.
I did recently encounter a database corruption, but this was after I had mistakenly unplugged my external hard drive where Syncthing was running in a VM… which is not a normal use case, I guess .
Thank you, i woriend only About unexpected sync corruption, like sync is running and someone close the lid (laptop goes to sleep), or if meanwhile sync someone shutdown destination pc
Thanks, i have Just tested several scenarions, and IT looks Fine (except of some tmp files which are created if you delete files in source folder meanwhile sync is running).
Now i am not ale to use syncthing without Global Discovery even if i am only at local…)
