Hello. I have switched from a Western Digital NAS to a Synology NAS and the setup is almost similar to what i had before.
I am syncing between 2 points. A and B , A sends only , B receives Only. Any deletions that happen on either device don’t get synced (i do them manually).
On my previous setup i was able to get a sync speed of 60MB/s , on this setup it doesn’t manage to get past 12MB/s , if it even gets there.
I have copied a file manually between my pc - router - synology nas and it copies with 110MB/s. So the LAN/NAS/HDD doesn’t seem to be the bottleneck.
The reason i said the setup is similar is due to the fact that in my initial setup i was using my PC to do the sync between Point A to Point B.
L.E. The source is running v1.3.1-rc.2, Linux (64 bit) The received is running v1.3.0, Linux (ARM)
