Just installed syncthing on my archlinux server, and i try to sync with my phone.
What i did :
add each device to the other one
-add the share to each device
-tried the sync by creating dummy files on each device (1 file 1 directory on archlinux,3files on android)
What i get :
no sync
-green button on the share in the webui for each device
blue button on the device in the webui for each device
-tried to change dynamic address with ip address without success
-tried 3 times the configuration by the start
-on the webui, it shows me the files on the local and global share as they are on local share,without taking in account what are the files on the other share
Did you create the folder on one side and accepted it on the other, or did you create it independently on both sides?
If the latter, did you use the same folder id (not folder name)?
Both side have the same id share.
What i did :
-create a folder on archlinux side
-then create the share pointing on this folder in the webui
-on android, accept the share in the device section, make it point to an existing folder
