Hi. Version of SyncThing 0.14.44. We have some problem with syncing files. For example: we need create some file with special name and always save are work in this file, without increment in filename. Problem in syncing: SyncThing cant synchronisate this file, even he have new date of creation.
That’s not true, if the modification timestamp changes, the file will be rescanned and resynced with others.
If you are seeing something else, you should check the logs on both sides.
Thanks for the answer
