Hello!
As always, many thanks for an amazing tool - it works so well for me, and with so few problems!
I’m having an issue with some sync conflicts being created - even though the original and conflict file generate the same md5
hash. I think I know why this might be happening - but I stand to be corrected:
- The files are ‘large’ and reasonably old. I suspect they were indexed by some machines in the sync cluster before the block size was changed for large files;
- A new machine is then added to the sync cluster, with a shared folder which has been pre-seeded with necessary files (due to the size of the folder making it impractical to wait for Syncthing to populate it);
- This new machine then indexes the files with the new, larger block size - creating files which are seemingly in conflict with those already indexed by other machines.
Is there a good case for a periodic conflict cleaner which:
- Scans the filesystem for conflict files and their original counterparts;
- Performs a complete-file hash to determine a non-required conflict;
- Remove the conflict file;
- Update the cluster’s records with the appropriate blocks for the original file.
I know - it’s easy for me to write and suggest…
Thanks!
