Hello,
I’m running v0.14.45 on a Mac.
During the last days, I encountered, that I can not open a connection to the Syncthing WebGUI via any Browser anymore.
Syncthing is running fine, which I can see, when connecting to WebGUIs of other syncthing devices (The Mac device is show as connected and it syncs).
In the Logs under ~/Library/Logs/Syncthing.log
, I can not find anything unusual, or a errormessage.
(I renamed all foldernames to Documents… https://pastebin.com/90da31nA)
The ~/Library/Logs/Syncthing-Errors.log
is empty.
I usually log in via a Bookmark set in FireFox Browser.
Either
https://localhost:8384/?lang=en
or
https://192.168.168.66:8384/?lang=en
But atm, FF is just telling me:
Unable to connect
Firefox can’t establish a connection to the server at localhost:8384.
(or the IP-Address or just HTTP)
The config.xml seems unaltered, but here it is, except the folder configuration:
<gui enabled="false" tls="true" debugging="false">
<address>0.0.0.0:8384</address>
<user>user</user>
<password>$encryptedpassword</password>
<apikey>MyAPIKey</apikey>
<theme>default</theme>
</gui>
<options>
<listenAddress>default</listenAddress>
<globalAnnounceServer>default</globalAnnounceServer>
<globalAnnounceEnabled>true</globalAnnounceEnabled>
<localAnnounceEnabled>true</localAnnounceEnabled>
<localAnnouncePort>21027</localAnnouncePort>
<localAnnounceMCAddr>[ff12::8384]:21027</localAnnounceMCAddr>
<maxSendKbps>0</maxSendKbps>
<maxRecvKbps>0</maxRecvKbps>
<reconnectionIntervalS>60</reconnectionIntervalS>
<relaysEnabled>true</relaysEnabled>
<relayReconnectIntervalM>10</relayReconnectIntervalM>
<startBrowser>false</startBrowser>
<natEnabled>true</natEnabled>
<natLeaseMinutes>60</natLeaseMinutes>
<natRenewalMinutes>30</natRenewalMinutes>
<natTimeoutSeconds>10</natTimeoutSeconds>
<urAccepted>3</urAccepted>
<urSeen>3</urSeen>
<urUniqueID>GagCOQVR</urUniqueID>
<urURL>https://data.syncthing.net/newdata</urURL>
<urPostInsecurely>false</urPostInsecurely>
<urInitialDelayS>1800</urInitialDelayS>
<restartOnWakeup>true</restartOnWakeup>
<autoUpgradeIntervalH>12</autoUpgradeIntervalH>
<upgradeToPreReleases>false</upgradeToPreReleases>
<keepTemporariesH>24</keepTemporariesH>
<cacheIgnoredFiles>false</cacheIgnoredFiles>
<progressUpdateIntervalS>5</progressUpdateIntervalS>
<limitBandwidthInLan>false</limitBandwidthInLan>
<minHomeDiskFree unit="GB">1</minHomeDiskFree>
<releasesURL>https://upgrades.syncthing.net/meta.json</releasesURL>
<overwriteRemoteDeviceNamesOnConnect>false</overwriteRemoteDeviceNamesOnConnect>
<tempIndexMinBlocks>10</tempIndexMinBlocks>
<trafficClass>0</trafficClass>
<weakHashSelectionMethod>auto</weakHashSelectionMethod>
<defaultFolderPath>~</defaultFolderPath>
<setLowPriority>true</setLowPriority>
<minHomeDiskFreePct>0</minHomeDiskFreePct>
</options>
I start syncthing from a loaded plist in ~/Library/LaunchAgents/syncthing.plist
via launchctl load ~/Library/LaunchAgents/syncthing.plist
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Label</key>
<string>net.syncthing.syncthing</string>
<key>ProgramArguments</key>
<array>
<string>/Applications/syncthing</string>
</array>
<key>EnvironmentVariables</key>
<dict>
<key>HOME</key>
<string>/Users/user</string>
<key>STNORESTART</key>
<string>1</string>
</dict>
<key>KeepAlive</key>
<true/>
<key>LowPriorityIO</key>
<true/>
<key>ProcessType</key>
<string>Background</string>
<key>StandardOutPath</key>
<string>/Users/user/Library/Logs/Syncthing.log</string>
<key>StandardErrorPath</key>
<string>/Users/user/Library/Logs/Syncthing-Errors.log</string>
</dict>
</plist>
If I stop syncthing (via launchctl unload ~/Library/LaunchAgents/syncthing.plist
and start it by hand via /Applications/syncthing
I’m not able to get to the WebGui too.
Can somebody tell me, what else I could check?
