Some problems encountered when syncthing is synchronizing
  1. Through the in work directory, it keeps prompting to synchronize desktop.ini. I admit that this is a problem that I accidentally uploaded before. However, both computers I synchronized with were configured to ignore this synchronization problem. It has been stuck here today, so I manually deleted this file. However, it is still stuck here. Even if I restart syncthing, it doesn’t help
I’ve been troubled by many similar problems with syncthing recently, so I hope someone can give me some guidance. Thank you.
log list
2025-05-26 14:27:06 My name is "tiger-cloud"
2025-05-26 14:27:06 ...
2025-05-26 14:27:06 Device MEUOLK2-BJRDKE2-X7CSL52-XLAFPSU-FFJUGLC-SRMZ52F-ZT2JTP3-DZSD6QU is "adam-win-16" at [dynamic]
2025-05-26 14:27:06 Device STFCYES-5U5ZQ7J-XTVYHDO-AWXKEQ2-YBRY2GR-ZRJ2O3G-OPNZFHM-YBR3HAX is "adam-win-32" at [dynamic]
2025-05-26 14:27:06 Ready to synchronize "install" (jfsnj-d6vux) (sendonly)
2025-05-26 14:27:06 Ready to synchronize "in work" (juzxg-rmpax) (sendreceive)
2025-05-26 14:27:06 Ready to synchronize "roaming" (zwd3f-rplq6) (sendreceive)
2025-05-26 14:27:06 Completed initial scan of sendreceive folder "roaming" (zwd3f-rplq6)
2025-05-26 14:27:10 Completed initial scan of sendonly folder "install" (jfsnj-d6vux)
2025-05-26 14:27:14 Completed initial scan of sendreceive folder "in work" (juzxg-rmpax)
2025-05-26 14:28:01 Established secure connection to MEUOLK2 at 127.0.0.1:22000-127.0.0.1:55586/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-622VV8R6DVBC242LQ6D2VU1E2C
2025-05-26 14:28:01 Device MEUOLK2 client is "syncthing v1.29.6" named "adam-win16" at 127.0.0.1:22000-127.0.0.1:55586/tcp-server/TLS1.3-TLS_AES_128_GCM_SHA256/LAN-P10-622VV8R6DVBC242LQ6D2VU1E2C
2025-05-26 14:28:02 Ignoring folder "install" (jfsnj-d6vux) from device MEUOLK2-BJRDKE2-X7CSL52-XLAFPSU-FFJUGLC-SRMZ52F-ZT2JTP3-DZSD6QU since it is in the list of ignored folders
2025-05-26 14:28:02 Ignoring folder "roaming" (zwd3f-rplq6) from device MEUOLK2-BJRDKE2-X7CSL52-XLAFPSU-FFJUGLC-SRMZ52F-ZT2JTP3-DZSD6QU since it is in the list of ignored folders
2025-05-26 15:52:32 Listen (BEP/tcp): TLS handshake: tls: first record does not look like a TLS handshake
2025-05-26 16:15:03 Ready to synchronize "roaming" (zwd3f-rplq6) (sendreceive)
2025-05-26 16:15:03 Restarted folder "roaming" (zwd3f-rplq6) (sendreceive)
2025-05-26 16:15:03 Completed initial scan of sendreceive folder "roaming" (zwd3f-rplq6)
2025-05-26 16:15:10 Ready to synchronize "install" (jfsnj-d6vux) (sendonly)
2025-05-26 16:15:10 Restarted folder "install" (jfsnj-d6vux) (sendonly)
2025-05-26 16:15:13 Completed initial scan of sendonly folder "install" (jfsnj-d6vux)
I would guess it’s likely https://github.com/syncthing/syncthing/issues/7474. In short, you probably need to ignore the file on the 3rd device (which is visible as “Inactive” in the screenshot).
