Andy
(Andreas Kaelber)
November 11, 2015, 8:29am
#1
Hello together,
I use 4 Synology Server and especially on 2 Servers I test Syncthing for using. With version v0.12.2 if have some strange differences, like “out of syncing”, differences in the content and so one, as follow:
In all cases and because also with version 0.11.x I have the problem with “out of sync” issues, I using the option “ignore permissions”. But I can´t imagine, if there problems with wrong settings or others.
wweich
November 11, 2015, 8:39am
#2
On the two out of sync folders, you have 4 Items (512 Byte) which cannot be synced.
To check which files and what the problem is, please open the lists for not synced objects and failed objects.
Andy
(Andreas Kaelber)
November 11, 2015, 8:45am
#3
Thanks, I know, but for me is not possible to generate any actions in this case, because the files are deleted in the past or other such issues are happen. Maybe is good to have a reset button to renew the index, because a new scan for such issues is no solution.
calmh
(Jakob Borg)
November 11, 2015, 9:13am
#4
Hm? This is exactly what scanning does, detecting removed files and so on.
Andy
(Andreas Kaelber)
November 11, 2015, 9:40am
#5
I have the message “Out of Sync Items”…
Andy
(Andreas Kaelber)
November 11, 2015, 9:44am
#7
…and in the other cases I have differences in the size.
calmh
(Jakob Borg)
November 11, 2015, 9:52am
#8
Yes, but what is the error on those files, if you click “4 items” beside “failed items”?
oppiman
(Mike O)
November 11, 2015, 10:03am
#10
I have seen this myself.
Happened when I deleted a folder with subfolders.
Seemingly the “delete folder” was issued before all files in it were gone.
However, with 12.2 this resolves after a few scan cycles.
Andy
(Andreas Kaelber)
November 11, 2015, 10:20am
#11
Because of the size differences, I found out, it may possible, that is a browser problem. But I don´t know exact, if there is a cache issue or others. The above pictures I make in may daily FireFox browser. If I use Google browser, I see no differences. But is my first use…
calmh
(Jakob Borg)
November 11, 2015, 11:00am
#12
There are probably ignored files in those directories that are preventing them from being deleted.
wweich
November 11, 2015, 11:03am
#13
According to the screenshots, he does not use ignores.
calmh
(Jakob Borg)
November 11, 2015, 11:48am
#14
That’s true. What is in those directories?
Andy
(Andreas Kaelber)
November 11, 2015, 12:25pm
#15
The complet content of the folders “Ablage” and “ST12”
Synology Server 712
\synology-712\ablage.nomedia
\synology-712\ablage.stfolder
\synology-712\ablage\Broetje.xls
\synology-712\ablage\contacts.csv
\synology-712\ablage\contacts.txt
\synology-712\ablage\desktop.ini
\synology-712\ablage\Kontakte.pst
\synology-712\ablage\Outlook Kontakte Nokia 6120 Felsomat v001.xls
\synology-712\ablage\Outlook Kontakte Nokia 6300 v001.xls
\synology-712\ablage\Outlook Kontakte Nokia 6300 v002.xls
\synology-712\ablage\Outlook Kontakte Nokia 6300 v003.xls
\synology-712\ablage\Outlook Kontakte Nokia AK v001.xls
\synology-712\ablage\Outlook Kontakte Nokia E51 v001.xls
\synology-712\ablage\Outlook Kontakte Nokia IK v001.xls
\synology-712\ablage\Outlook Kontakte Siemens GigaSet v001.xls
\synology-712\ablage\Outlook Kontakte Siemens S65 v001.xls
\synology-712\ablage\Outlook Kontakte.xls
\synology-712\ablage\Outlook Telefonkontakte.xls
\synology-712\ablage\Programm_Referenten_FIM_HH_2015.pdf
\synology-712\ablage\reach_statement_en.pdf
\synology-712\ablage\Speisekarte.pdf
\synology-712\ablage\Telefon- und Emailverzeichnis.xlsx
\synology-712\ablage\Zarafa alle Kontakte 2015-03-01 (Automatisch gespeichert).xlsx
\synology-712\ablage\Zarafa alle Kontakte 2015-03-01.xlsx
\synology-712\ablage\Zarafa alle Kontakte 2015-05-05.CSV
\synology-712\ablage\Zarafa alle Kontakte 2015-05-05.sync-conflict-20151111-090617.xlsx
\synology-712\ablage\Zarafa alle Kontakte 2015-05-05.xls
\synology-712\ablage\Zarafa alle Kontakte 2015-05-05.xlsx
\synology-712\ablage\Zarafa alle Kontakte 2015-11-05.xls
\synology-712\ablage\Zarafa alle Kontakte.xls
\synology-712\ablage\Zarafa alle Kontakte.xlsx
\synology-712\ablage\ZarafaKontakte.xls
\synology-712\ablage\ZarafaKontakte2.xls
\synology-712\ablage\ZarafaKontakteAlle.xls
Synology Server 412
\synology\cloudstation\SyncTest\ST12\Synology\BTsync##### Ignore #####
\synology\cloudstation\SyncTest\ST12\Synology\Syncthing##### Ignore #####
\synology\cloudstation\SyncTest\ST12.stfolder
\synology\cloudstation\SyncTest\ST12\Synology\Syncthing##### Ignore #####.stfolder
\synology\cloudstation\SyncTest\ST12\Synology\BTsync##### Ignore #####.stfolder
\synology\cloudstation\SyncTest\ST12\Synology\BTsync##### Ignore #####.stignore
\synology\cloudstation\SyncTest\ST12\Synology\Syncthing##### Ignore #####.stignore
\synology\cloudstation\SyncTest\ST12\Synology\adm_0_99c.spk
\synology\cloudstation\SyncTest\ST12\Synology\ddclient_201504072200.conf
\synology\cloudstation\SyncTest\ST12\Synology\Init_3rdparty_1.5.spk
\synology\cloudstation\SyncTest\ST12\Synology\Init_3rdpartyHelp_1.1.spk
\synology\cloudstation\SyncTest\ST12\Synology\net2ftp1.00-002.spk
\synology\cloudstation\SyncTest\ST12\Synology\spk-roundcube_noarch_1.0.0-2.spk
\synology\cloudstation\SyncTest\ST12\Synology\SQLBuddy-1.3.3-002.spk
\synology\cloudstation\SyncTest\ST12\Synology\Synology Cloud Station-3.2-3482.exe
\synology\cloudstation\SyncTest\ST12\Synology\Synology Cloud Station Drive-4.0-4055.exe
\synology\cloudstation\SyncTest\ST12\Synology\Synology Cloud Station Drive-4.0-4055.msi
\synology\cloudstation\SyncTest\ST12\Synology\SynologyAssistantSetup-5.2-5566.exe
\synology\cloudstation\SyncTest\ST12\Synology\webmin_1.600-002.spk
\synology\cloudstation\SyncTest\ST12\Synology\webogram_noarch_20140224-6.spk
Andy
(Andreas Kaelber)
November 11, 2015, 12:26pm
#16
Indead, if I delete all cache content of FireFox, it seems, all is okay … ?
calmh
(Jakob Borg)
November 11, 2015, 1:19pm
#17
I’m not sure if your paste is missing slashes, but I’m going to assume it is and interpret
as
\synology\cloudstation\SyncTest\ST12\Synology\BTsync\##### Ignore #####\.stignore
as both “BTsync” and “##### Ignore #####” are mentioned in the screenshot above, and .stignore is itself an ignored file which would block the delete of those directories.
Andy
(Andreas Kaelber)
November 11, 2015, 1:35pm
#19
Sorry, no. For the issue Synology-412 I send you a screenshot of the “flat view” of Freecommander
calmh
(Jakob Borg)
November 11, 2015, 4:17pm
#20
That’s a weird flat view. How do you manage to have multiple folders and files with the same name in the same place?
Andy
(Andreas Kaelber)
November 11, 2015, 4:59pm
#21
This is a function of my file browser
http://freecommander.com
If you have a lot of folders and subfolders, you can view all in one flat. This is great for such things! …
