I’m currently trying Syncthing on 3 PC - all ubuntu based.
They are “behind” ISP routers where Upnp are activated.
WebGUI works on all pc.
I wonder about the firewall(s) : are the defaults ubuntu firewall settings OK for Syncthing or should I change something ?
I should have tested with “smaller” folders but actually a 7 GB share took about 12 hours to “first” synchronize between 2 pc. Is this the intended pace ?
I suggest you generate a single large file, and see what sort of performance you can achieve with that.
At the same time, you might want to monitor CPU/Memory/IO usage to see where the bottleneck is.
Also, if you are using some UI wrapper around syncthing, they sometimes start syncthing with a lower process priority which might effect the performance.
Is it upload or download? How did you measure? Note that the GUI reports in bytes per second, which is roughly a tenth of bits per second with ADSL framing overhead etc… The default settings should for sure saturate an ADSL connection in any direction, with anything faster than phone hardware… It sure does for me.
About ADSL, these are the datas to be found in ISP routers’ admin.
About transferring those are the rates given by syncthing-gtk - which are quite the same as the webGUI :
download : about 100 k B ps
upload : about 50-90 B ps
(note for myself : check english & french translations for bits, bytes, octets and usual symbols for those units, my misunderstanding may come from that)
The web GUI reports in B/s (capital “B”, bytes per second). So if you see “100 kB/s” there, that is roughly 1 Mb/s (lowercase “b”, bits per second). Perhaps there is confusion there? Otherwise I’m not sure what is limiting your rate…
