I’m getting this as well every time I bring my Macbook out of hibernation. I seem to remember a similar issue a year or so back when an earlier release wasn’t signed properly.
Ron
I’ve re-uploaded correctly signed binaries so if you download those manually from GitHub, or downgrade to 0.14.14 and let it upgrade again, you should be back on track with a signed binary.
I’m still having the firewall issue though. I made sure to remove syncthing from the accepted applications in the firewall settings, but I’m still getting the popup.
@ronmc can you check and see if you still get the issue on your side?
It’s working for me, thanks.
I downgraded to 0.14.14 by renaming the syncthing.old in the runtime folder and restarting. Then the auto upgrade kicked in and picked up the new version.
Ron
Works for me now. I was replacing the old unsigned binary with the signed binary manually but apparently the OS didn’t pick up the change. After downgrading and letting Syncthing update itself all is fine.
