Thanks! I might give that a go if the issue persists. If I run the server on frame and the client on wsl-linux, they will communicate by LAN.
I don’t see why a VPN would help here. (and, if using one, then why not simply Wireguard)
As @bt90 mentioned: “It’s still a LAN conection as properly reported from the other node.”
Since version 2, yes. Version 1 of WSL was not a VM.
As I mentioned, I have already considered mirrored networking in WSL, but it broke some things. And I first want to understand exactly what it does and what implications it has before making the switch.
I wouldn’t move to a VPN right now. The real course of action, first, is to use iperf to test the communication speed/bandwidth between your two instances of syncthing .
IPerf will push the network and tell you exactly whether you have a network bandwidth problem or not.
As far as the choice between using WireGuard and/or Tailscale:
Tailscale is a pure peer-to-peer VPN that uses WireGuard for its communication so it is WireGuard.
It’s needed primarily when you have multiple subnets or routers in the way or the internet in the way. Each thing server gets its own IP address on a peer-to-peer network and they’re all on the same subnet regardless of where they are in the world.
An example of using Tailscale in a Syncthing environment this is when you want to access the web admin console for a Syncthing server that you’re not sitting in front of. The default is to only allow that web console to be accessed locally on that computer. If each Syncthing server has a Tailscale IP address, then you can bring up the GUI for any Syncthing server from anywhere. All without modifying the Syncthing configuration to compromise security.
Iperf should be in your default repositories so it’s a very quick and simple test to find out if there’s a problem with the network or not.
I also don’t see how a VPN would help here. As you correctly state, a VPN puts all machines on the same subnet. So it looks like a LAN. But it doesn’t magically turn a WAN into a LAN.
WireGuard absolutely supports peer-to-peer VPN connections without Tailscale. The distinction is that WireGuard is the VPN protocol and software while Tailscale is a management and connectivity system built around WireGuard.
My understanding is that pure WireGuard does not know how to do NAT traversal, which means that you have to manually set up the transfer between NATted networks. With Tailscale it’s all automated. Any device can reach any other device, no matter where they are on the internet, without modifying anything anywhere.
There’s another good reason for using Tailscale even if you’re not using it to transfer your data. Tailscale provides an excellent way to access all of your web browser management consoles that are local-only listeners by default on each individual Syncthing server.
If you’re at one PC and you want to see the admin console of other Syncthing devices, you can’t do that over the network without help or modifying the software (because Syncthing is designed to only allow you to run the management console from the server that it’s actually running on).
Tailscale offers a feature called Serve, which is an excellent way to access the Syncthing management console remotely without exposing Syncthing’s web interface to the internet. It works as a secure reverse proxy running on the same computer as Syncthing. You leave Syncthing management console standard settings and Tailscale Serve makes that interface available to authorized devices on your tailnet. It’s not just for data.
Today I have a router at home that supports a WireGuard VPN server so if I’m away from home I use a WireGuard client to access my home network.
Prior to having a router with this feature, I relied on Tailscale to give me access to any of my computers from anywhere I wanted access to them. No port forwarding and no need to worry about extra encryption or security. It’s all encrypted.
For remote access I like to use a remote control program called NoMachine. Unfortunately nomachine does not support NAT router transversal and you can’t access your machines from anywhere in the world without port forwarding and such. Tailscale removes that problem from the equation. I simply give nomachine the Tailscale IP address.
