Slow connection over TCP LAN connection
I had issue with slow syncing over syncthing and recently I found out about firewall setting and how to make a connetion TCP LAN. But I still get compression: metadata only and when this happens the transfer gets slow again. Any idea why it is happening and what I should check to troubleshoot it?
The compression is a setting and is most likely not reason why the synchronisation speed is low.
Could you give us more details about the involved hardware and the amount and size of the files you’re synchronizing?
Sorry for late reply, I think the issue is my router, it was working fine with syncthing but now it shows only 1 connection. I switch from my router to hotspotting with my phone and the LAN speed got fixed.
