Same file different directories
I want to sync my keypass database among between alinux machine and an android machine. The file lives in different directories on linux and android. I do not have root on the android machine. Is there some way to tell syncthing to sync path1/database.kdb on one machine with path2/database.kdb on another?
Of cause you can select whichever folder you want. The only thing Syncthing cares about is the shared folder name (the name you give it inside the Syncthing ui) and the folder structure within the shared folder.
