Rusty, Audrius, Jakob, First I want to thank you for so much help and responsiveness!
We have successfully used this software for several years and contributed nothing, so I would like to “pay back” with anything I can do to improve the product. I will try any suggestions you have at this point. I think our system is interesting and possibly a good “test network” if there is something you would like to observe.
It is my opinion that the connection requests are now permanently in the config files. I will have the best result if I go to all 120 devices and edit their config files. (This is a difficult task as they are located in 120 different cities across the USA. We have occasional remote access.)
At this point, I am interested in any ideas you have for the “cause”. Since I do not want to fix all the config files and then have it “replicate” the problem again.
Thank you!!!
