Thank you for the lightning fast response!
Using the credentials as you suggest make much more sense. Thanks for that, too.
It still does not work but I have to look further into the ID-thing. The output of curl suggests, its not the user authorization that fails, but that there is something wrong with the ID. And that although the ID has been copied from the GUI > Actions > Show ID. Hmm…
[admin@...U4 ~]# curl -vv -k -X POST -H "X-API-Key:ABCDEF-...-ABCDEF> https://user:password@127.0.0.1:8090/rest/system/reset?folder=BLAH
* Trying 127.0.0.1...
* Connected to 127.0.0.1 (127.0.0.1) port 8090 (#0)
* Server auth using Basic with user 'syncthing'
> POST /rest/system/reset?folder=BLAH HTTP/1.1
> Host: 127.0.0.1:8090
> Authorization: Basic c3luY3RoaWsomethingTM2NC1zdi00
> User-Agent: curl/7.43.0
> Accept: */*
< HTTP/1.1 401 Unauthorized
< Content-Type: text/plain; charset=utf-8
* Authentication problem. Ignoring this.
< Www-Authenticate: Basic realm="Authorization Required"
< X-Content-Type-Options: nosniff
< Date: Sun, 24 Jul 2016 09:04:58 GMT
< Content-Length: 15
Not Authorized
* Connection #0 to host 127.0.0.1 left intact
And to your question why I’m doing this:
tl;dr
Resilience tests.
Long boring story:
The organization I work with is syncing data since 15 years in all sorts of ways to all sort of operating systems. Syncthing is by
*far* the most satisfying solution I’ve ever came across.
It’s meshed, it traverses different networks, it’s stable, it’s reliable, it’s stable, it’s light weight, it works with high latency lines (like from Continents to ships that sometimes have to uplink at all), it’s encrypted, it’s stable, it’s remote administrable, it’s free (!), it’s open source, it’s still stable.
In three words? It’s just great. Two Words? Simply great.
Only now and then there is a condition in which it will fail. The most common (in the organization I am working with): renames. The second most common: Things that happen while one node is offline.
Once a directory is renamed from, say “RESULTS” to “results” mayhem ensues. I though it might kind of work when only case sensitive filesystems are involved, but even HFS+ to NTFSv5 have problems. By manually cleaning up (via ssh) and then giving syncthing the hint (via REST) to ditch the index things can work again.
So I am writing a documentation for my colleagues to help them try and figure out what to do.
