Hi!
I’m trying to setup a really basic two user Syncthing node using just one syncthing instance (FreeNAS). I am aware that there are discussion in place on how to sync permission flags, and I’m also aware that I could run multiple instances of Syncthing. My setup is really simple so I’m hoping to do it in this way.
To simplify, I have 2 “clients” (Mac/Win) and one “server”. On the server I have 3 users: user1
, user2
, syncthing
. Not surprising is that Syncthing is running (in a jail) under the user syncthing
I created 2 folders, Sync/User1
and Sync/User2
, with setgid
set and owned by user1:user1group
and user2:user2group
respectively. The user syncthing
is part of user1group
and user2group
The permissions are 770
and Syncthing is set to ignore permissions.
The syncthing folders are created in Sync/User*/
folders.
In my mind this should work: Syncthing, since is in the groups user1group
and user2group
has full access to Sync/User*/
folders. When it creates a file, that file will be owned by syncthing
, but, since setgid
flag is set, the group will be set to userxgroup
, hence userx
can also have access (locally or via smb).
But in the real world Syncthing says: permission denied. The funny part is that if I su - syncthing
I can write in the folder as expected.
What I’m doing wrong? Maybe Syncthing needs to be the owner? But why? Can the FreeBSD jail be the problem?
Thanks in advance for your help
