Thanks.But one assumpe is someone get the private key,maybe he can get the sensitive information from message. that is big risk for us. we are forbidden to use any private key which it is not be encrypt.
You have your policy then and you should follow it. Unfortunately Syncthing doesn’t support encrypted private keys and I’m not sure I see any security gain in doing so, unless paired with something like hardware smartcards / security modules which we also don’t support.
Yea.maybe someone can add a module to encrypted&decrypted the key ,even store the password.but syncthing is open source program,everyone can get the code.so i think currently there no good way to solve my problem from syncthing side .I spend much time on syncthing to fits our solution , because this we have to give up it .
