I am running a pool of three nodes, each behind a router and NAT’ed up. Discovery seems to run correctly but after a while (once stablished a relayed connection), the connection shuts down and does not restart. How can I debug this issue?. Is this my fault or relay one?
Here you are my log (BTW, the pull: peer… message is not correct, no changes have occurred during shutdown…):
[TEWOO] 16:32:43 INFO: syncthing v0.12.22 "Beryllium Bedbug" (go1.6.1 windows-amd64) WIN-SERVER\Administrator@WIN-SERVER 2016-04-13 09:52:12 UTC
[TEWOO] 16:32:43 INFO: My ID: XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX
[TEWOO] 16:32:44 INFO: Single thread hash performance is ~111 MB/s
[TEWOO] 16:32:44 OK: Ready to synchronize PUBLIC_RESULTS (read-write)
[TEWOO] 16:32:44 INFO: Using discovery server https://discovery-v4-1.syncthing.net/?id=XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX
[TEWOO] 16:32:44 INFO: Using discovery server https://discovery-v4-2.syncthing.net/?id=XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX
[TEWOO] 16:32:44 INFO: Using discovery server https://discovery-v4-3.syncthing.net/?id=XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX
[TEWOO] 16:32:44 INFO: Using discovery server https://discovery-v6-1.syncthing.net/?id=XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX
[TEWOO] 16:32:44 INFO: Using discovery server https://discovery-v6-2.syncthing.net/?id=XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX
[TEWOO] 16:32:44 INFO: Using discovery server https://discovery-v6-3.syncthing.net/?id=XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX
[TEWOO] 16:32:44 INFO: Device XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX is "syncthing-PC" at [dynamic]
[TEWOO] 16:32:44 INFO: Device XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX is "syncthing-Server" at [dynamic]
[TEWOO] 16:32:44 INFO: No automatic upgrades; STNOUPGRADE environment variable defined.
[TEWOO] 16:32:44 INFO: GUI and API listening on 127.0.0.1:8384
[TEWOO] 16:32:44 INFO: Access the GUI via the following URL: http://127.0.0.1:8384/
[TEWOO] 16:32:44 INFO: Completed initial scan (rw) of folder PUBLIC_RESULTS
[TEWOO] 16:32:49 INFO: Joined relay relay://91.121.160.153:22067/?id=XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX&pingInterval=1m0s&networkTimeout=2m0s&sessionLimitBps=0&globalLimitBps=0&statusAddr=:22070&providedBy=KS
[TEWOO] 16:32:55 INFO: No UPnP device detected
[TEWOO] 16:33:10 INFO: Established secure connection to XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX at 10.0.2.15:52834-92.222.95.0:443 (relay-dial)
[TEWOO] 16:33:10 INFO: Device XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX client is "syncthing v0.12.22" named "SERVER_2008"
[TEWOO] 16:50:30 INFO: Connection to XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX closed: device paused
[TEWOO] 16:50:34 INFO: Puller (folder "PUBLIC_RESULTS", file "REPO\\PERSON4\\SESSION\\IMG_8804.JPG"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[TEWOO] 16:50:34 INFO: Puller (folder "PUBLIC_RESULTS", file "EXPERIMENTS\\JOBS_AND_CONTROL\\EXPERIMENTS RESEARCHER\\STUDIES EXPERIMENTS\\PERSON3\\PERSON3_ORTO\\Thumbs.db"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[TEWOO] 16:50:34 INFO: Connection to XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX closed: read tcp 10.0.2.15:52834->92.222.95.0:443: use of closed network connection
[TEWOO] 16:50:34 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
[TEWOO] 16:50:35 INFO: Puller (folder "PUBLIC_RESULTS", file "REPO\\PERSON4\\IMG_6834.JPG"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[TEWOO] 16:50:35 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
[TEWOO] 16:51:37 INFO: Established secure connection to XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX at 10.0.2.15:54584-91.121.160.153:22067 (relay-accept)
[TEWOO] 16:51:37 INFO: Device XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX client is "syncthing v0.12.22" named "SERVER_2008"
[TEWOO] 16:51:52 INFO: Connected to already connected device (XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX)
[TEWOO] 16:52:25 INFO: Connection to XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX closed: device paused
[TEWOO] 16:52:29 INFO: Puller (folder "PUBLIC_RESULTS", file "REPO\\PERSON1\\STUDY\\_MG_5884.JPG"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[TEWOO] 16:52:29 INFO: Connection to XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX closed: read tcp 10.0.2.15:54584->91.121.160.153:22067: use of closed network connection
[TEWOO] 16:52:29 INFO: Puller (folder "PUBLIC_RESULTS", file "REPO\\PERSON2\\STUDY\\IMG_7025.JPG"): pull: peers who had this file went away, or the file has changed while syncing. will retry later
[TEWOO] 16:52:29 INFO: Puller: final: peers who had this file went away, or the file has changed while syncing. will retry later
Finally, at 17:02:25 it reconnects again… Isn’t it too much time?
Thanks in advance,
Jose
