Hi all,
Environment:
- I have multiple Syncthing Nodes sharing multiple folders
- One of the Nodes shares only a subset of this folders and is running within a Docker container
- currently the only persistent config are the *.pem files
Plan:
I want to be able to set this node up automatically. Persistend data in this case are the *.pem files, the global and the local config. The folders live completly within temporary docker volumes, same with the DB.
Questions:
- How will Syncthing behave if I delete this Node and set it up completly from scratch without DB and folder data?
- Is this “secure” from a data lose perspective or is there any scenario where the empty folders will be synced back to all other nodes?
- If this folders contain a .stignore file initially, how will Syncthing behave (two cases: if the are readded and if they already exist in the config XML)?
Thats it so far, I hope my thoughts are clear. If not just ask and thanks already for every input.
Thanks and best regards Robert
