Hello! We have a workbench with two servers:
Server 1: device1
CentOS release 6.6 (Final) 2x Intel® Xeon® Processor E5320 (8M Cache, 1.86 GHz, 1066 MHz FSB) 12Gb memory: 2x 4GB DDR2-667MHz 2x 2Gb DDR2-667MHz
Server 2: device2
FreeBSD 10.1-RELEASE Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz 12Gb memory: 2x 4GB DDR2-800MHz 2x 2Gb DDR2-800MHz
We have syncthing v0.11.5 installed on both servers. Servers are directly connected via 1000BASE-T twisted pair. Firewall is turned off on both servers. We are trying to syncronize 6Tb of data (about 50K files of size from 100kb to 10Gb) stored on device1 with device2 When Syncthing is running we see full utilization of physical memory and 3 of 8 physical cores loaded at 100% on "device1" Maximum transmission speed we ever noticed is 170Mbps. Maximum size of successfully transfered data is 1Tb. Both “device1” and “device2” randomly lose connections Sometimes sync just freezes while connections are still active. It can be resolved either with restart Syncthing on both servers or, sometimes, with just entering Syncthing web interface. We’re having same issue with all versions of Syncthing. With rsync we have a stable transfer at 500-600Mbps
Links to syncthing config files from both servers are below
"Device1" http://pastebin.com/N9Mgpmvh
"Device2" http:// pastebin.com/6ezhjGqs
