I have mix bunch of nodes like android, linux etc. I am using the 11 branch now. As far as I can tell the sync is ok in general except one interesting case in which I was using the 10.x branch with my all nodes.
This was when I was on 10.x branch so not sure if it is the same for 11.x. I had a node that has not synced for a while (couple months at least). So I ran ST on it. Well everything was fine except that the files that I deleted from the others when that node was offline for couple monhts, got copied back to others. I tend to think that ST would remember such deletetions, but in this case it did not. So what is the right behaviour in this situation? Should ST remember all the deleted files at all times, or should ST copy deleted files from a node that was offline for a while?
thanks
