I’m running syncthing on a Synology DS918+ NAS, and have a receive only folder on macos, which is writing to a network drive. The problem is at the mac end.
(I’m also syncing the same folder to another Synology DS918+ and that has completed the sync successfully).
It’s completed ~90% of the sync but now for every file I see this message in the log:
[HRXF4] 08:17:52 INFO: Puller (folder “Projects” (n--------n), file “EDITS/preproc_20190507/05_export/sessions/mat/1019_24m.mat”): sync /volumes/basis data archive/Luke/Projects/EDITS/preproc_20190507/05_export/sessions/mat/.syncthing.1019_24m.mat.tmp: operation not supported
The .tmp file it refers to does not exist.
I can find plenty of references on google to “operation not permitted”, but not “operation not supported”.
Would appreciate any help!
Luke
