Good day for all! I installed this Syncthing on Debian 10 webserver with parameters: sudo curl -o /usr/share/keyrings/syncthing-archive-keyring.gpg https://syncthing.net/release-key.gpg
echo “deb [signed-by=/usr/share/keyrings/syncthing-archive-keyring.gpg] https://apt.syncthing.net/ syncthing stable” | sudo tee /etc/apt/sources.list.d/syncthing.list
sudo apt-get update
sudo apt-get install syncthing
syncthing
From command line:
[LZMVY] 2022/08/04 23:03:18 INFO: TCP listener ([::]:22000) starting
[LZMVY] 2022/08/04 23:03:18 INFO: Loading HTTPS certificate: open /root/.config/syncthing/https-cert.pem: no such file or directory
[LZMVY] 2022/08/04 23:03:18 INFO: Creating new HTTPS certificate
[LZMVY] 2022/08/04 23:03:18 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
[LZMVY] 2022/08/04 23:03:18 INFO: QUIC listener ([::]:22000) starting
Seemd to be started, but when opening link “…overy-v4.syncthing.net/v2/?nolookup&id=LYXK…” I get “Not Found”
What not found? More info? The certificate? Or another thing?
