Hi
On my LAN I have 3 Win10 devices that reach to open upnp portforward in the gateway. Another device (armf raspbian) fails. Any idea please ? I changed config (NatLeaseMinutes=6
& NatRenewalMinutes=3
) so that there is more log entries and started STTRACE=upnp syncthing &
. All devices are 1.6.1
2020-06-15 11:31:43 My ID: SHORT-BBBBBBB-CCCCCCC-DDDDDDD-EEEEEEE-FFFFFFF-GGGGGGG-HHHHHHH
2020-06-15 11:31:44 Single thread SHA256 performance is 45 MB/s using crypto/sha256 (45 MB/s using minio/sha256-simd).
2020-06-15 11:31:45 Hashing performance is 40.99 MB/s
2020-06-15 11:31:45 Overall send rate is unlimited, receive rate is unlimited
2020-06-15 11:31:45 Using discovery server https://discovery.syncthing.net/v2/?noannounce&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2020-06-15 11:31:45 Ready to synchronize "Folder1" (Folder1-ID) (receiveonly)
2020-06-15 11:31:45 Ready to synchronize "Folder2" (Folder2-ID) (sendreceive)
2020-06-15 11:31:45 Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
2020-06-15 11:31:45 TCP listener ([::]:32571) starting
2020-06-15 11:31:45 Using discovery server https://discovery-v4.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2020-06-15 11:31:45 ...
2020-06-15 11:31:45 Completed initial scan of sendreceive folder "Folder2" (Folder2-ID)
2020-06-15 11:31:45 Using discovery server https://discovery-v6.syncthing.net/v2/?nolookup&id=LYXKCHX-VI3NYZR-ALCJBHF-WMZYSPK-QG6QJA3-MPFYMSO-U56GTUK-NA2MIAW
2020-06-15 11:31:45 GUI and API listening on 127.0.0.1:8384
2020-06-15 11:31:45 Access the GUI via the following URL: https://127.0.0.1:8384/
2020-06-15 11:31:45 My name is "Raspi"
2020-06-15 11:31:45 Device WIN101-BBBBBBB-CCCCCCC-DDDDDDD-EEEEEEE-FFFFFFF-GGGGGGG-HHHHHHH is "WIN101" at [dynamic]
2020-06-15 11:31:45 Device WIN102-BBBBBBB-CCCCCCC-DDDDDDD-EEEEEEE-FFFFFFF-GGGGGGG-HHHHHHH is "WIN102" at [dynamic]
2020-06-15 11:31:45 Device WIN103-BBBBBBB-CCCCCCC-DDDDDDD-EEEEEEE-FFFFFFF-GGGGGGG-HHHHHHH is "WIN103" at [dynamic]
2020-06-15 11:31:46 Completed initial scan of receiveonly folder "Folder1" (Folder1-ID)
2020-06-15 11:31:46 Established secure connection to WIN101-BBBBBBB-CCCCCCC-DDDDDDD-EEEEEEE-FFFFFFF-GGGGGGG-HHHHHHH at [IpV6-0]:39498-[IpV6-1]:22010/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2020-06-15 11:31:46 Device WIN101-BBBBBBB-CCCCCCC-DDDDDDD-EEEEEEE-FFFFFFF-GGGGGGG-HHHHHHH client is "syncthing v1.6.1" named "WIN101" at [IpV6-0]:39498-[IpV6-1]:22010/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2020-06-15 11:31:46 Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0
2020-06-15 11:31:46 Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0
2020-06-15 11:31:46 Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0
2020-06-15 11:31:46 Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0
2020-06-15 11:31:46 Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0
2020-06-15 11:31:46 Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0
2020-06-15 11:31:46 Established secure connection to WIN102-BBBBBBB-CCCCCCC-DDDDDDD-EEEEEEE-FFFFFFF-GGGGGGG-HHHHHHH at 192.168.0.49:50444-192.168.0.15:22015/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
2020-06-15 11:31:46 Device WIN102-BBBBBBB-CCCCCCC-DDDDDDD-EEEEEEE-FFFFFFF-GGGGGGG-HHHHHHH client is "syncthing v1.6.1" named "WIN102" at 192.168.0.49:50444-192.168.0.15:22015/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256
2020-06-15 11:31:47 Established secure connection to WIN103-BBBBBBB-CCCCCCC-DDDDDDD-EEEEEEE-FFFFFFF-GGGGGGG-HHHHHHH at 192.168.0.49:45912-192.168.0.20:22020/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2020-06-15 11:31:47 Device WIN103-BBBBBBB-CCCCCCC-DDDDDDD-EEEEEEE-FFFFFFF-GGGGGGG-HHHHHHH client is "syncthing v1.6.1" named "WIN103" at 192.168.0.49:45912-192.168.0.20:22020/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256
2020-06-15 11:31:56 Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0 finished.
2020-06-15 11:31:56 Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0 finished.
2020-06-15 11:32:00 Detected 1 NAT service
2020-06-15 11:32:15 Joined relay relay://46.223.16.186:34617
2020-06-15 11:34:56 Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0
2020-06-15 11:34:56 Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0
2020-06-15 11:34:56 Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0
2020-06-15 11:34:56 Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0
2020-06-15 11:34:56 Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0
2020-06-15 11:34:56 Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0
2020-06-15 11:35:06 Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on eth0 finished.
2020-06-15 11:35:06 Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on eth0 finished.
Thank you
