Problem with setting listener port
Is there any way to use the existing SSH port (port 22) instead of changing the listener port to 22000 on a Linux server? I’m unable to freely modify the port due to policy.
Please help :sob:
I’m not sure if it’s the best approach, or even possible if you have an SSH-server running as well which wants to listen on 22, but you are free to change Syncthing’s Sync Protocol Listen Address - in the GUI as well as directly in the config file; Syncthing Configuration — Syncthing v1.23.4 documentation
Just be aware that if you have non-default discovery settings that you may need to manually set this device’s address in the remote-device settings on other connected devices.
