Problem with Private Relay Server (persists)
Not on this topic, but what kind of speeds do you get from relays?
Like if you compare the speeds of syncthing relays with tailscale relays or cloud reverse proxies.
I eventually gave up on relay, it was just testing anyway, did not actually make use of it’s feature, and it’s more noisy for my use case than simple device to device setup since I have direct sight between hosts with no need of relaying/natting.
you should get the same speed since both are written in same language using same frameworks. i would expect a relay to generate less cpu load, though, since it’s only doing a part of work that the full client is doing.
