Hello, this is my first post, so I would also like to thank you for this great program!
Here’s my current problem, I have:
A. “Camera” folder on my android as a master folder
B. A PC.
If I delete a file from B this will never come back when syncing, Camera folder B displays 100% but in the right column the device listed (A) gets stuck on “Syncing 100%” and never gets “Up to date”.
Why is this happening? Is this a bug or a feature?
I tried what I think you meant (delete the file on the non-master side), but I can’t reproduce the above status. I get a red “out of sync” on the master side (which is correct) and everything else being “up to date”.
Sorry, seems like my text formatting went out… It was:
B. A PC.
Master is A (my android phone), what I’m trying to archeive is a simple mirror folder of what’s into my phone camera folder. Could be a windows 10 issue?
you need to press “override” on A to get all files back to B. I would also like this to happen automatically, but I understand all pros/cons). On Syncthing Android you need to use the web GUI for this, the “override” button is currently not implemented (see #396). I don’t know if Syncthing Silk for Android already has it.
