thank you for your long text. The adress http://127.0.0.1:10080/, dont work. The browser says: ERR_UNSAFE_PORT
I use Brave.
The problem is that I haven’t reconfigured anything in Windows. I simply haven’t used Syncthing for a while. But I didn’t knowingly change anything. So I can’t say what the problem is.
Port 443 is the official HTTPS port reserved by IANA, not 433. You can use any port that is not used by another program for any protocol though (that includes 433 for HTTPS, if unused by any program).
Also even if a port is reserved or registered by IANA, does not mean you strictly cannot use it for a different purpose than is defined. But I don’t know if that’s what you meant by “reserved”.
* PLEASE NOTE THE FOLLOWING: *
* ASSIGNMENT OF A PORT NUMBER DOES NOT IN ANY WAY IMPLY AN *
* ENDORSEMENT OF AN APPLICATION OR PRODUCT, AND THE FACT THAT NETWORK *
* TRAFFIC IS FLOWING TO OR FROM A REGISTERED PORT DOES NOT MEAN THAT *
* IT IS "GOOD" TRAFFIC, NOR THAT IT NECESSARILY CORRESPONDS TO THE *
* ASSIGNED SERVICE. FIREWALL AND SYSTEM ADMINISTRATORS SHOULD *
* CHOOSE HOW TO CONFIGURE THEIR SYSTEMS BASED ON THEIR KNOWLEDGE OF *
* THE TRAFFIC IN QUESTION, NOT WHETHER THERE IS A PORT NUMBER *
* REGISTERED OR NOT. *
