Hello everyone, I’m trying to replicate the same entry point for a folder shared among multiple devices, according to the manual the folder set tries to match the label, if this is not working then falls back to the id.
I have this condition: DEVICE1 = {base_folder}/foo/bar/my_folder
on DEVICE2 when I auto-approve the folder I get this as the result: DEVICE2 = {base_folder}/“foo bar my_folder”
if I do the approval manually I get the result I’m expecting: DEVICE1 = {base_folder}/foo/bar/my_folder
Is there any way to get the wanted path with the auto-approval? Is there any setting I should modify? Any config I should change?
Thanks a lot in advance
