Hello, and sorry if I’m missing something evident.
When I create a folder, I see I can add it to known remote machines right away. I also see, in the general settings, that I can automatically receive folders from certain machines when they’re created remotely.
Let’s assume I don’t want to share anything proactively. I’m missing an easy way of adding a remote folder, from an already known machine, so it starts to sync locally (for example if I have disabled the automatic addition mentioned above).
Is this not supported for security/privacy reasons? I can think only of remotely accessing the machine holding the folder, and sharing from there. This is also somewhat inconvenient if I have a bunch of folders to select.
I hope I have explained myself, thanks for your advice.
