Despite my readings and searchs, I couldn’t determine what would the behavior of Syncthing if in my shared folder a subfolder is actually a bind-mount. Will Synchting sync its content as if it was a normal folder, will it skip it, etc.? Also, is there any way to change that behavior?
What I would like to do is to avoid to sync its content. Is that possible?
