Port Forwarding on Raspberry Pi
Hi, I’m using Syncthing on a Raspberry Pi 3 as an always-on device to sync my files to it (the OS is installed onto a usb drive using BerryBoot) and want to be able to connect to the GUI from a remote network as well as connect to it from my laptop/tablet even when I’m away from home. I have UPnP enabled it just doesn’t seem to work and I need a touch of help with identifying exactly what I need to input on the port forwarding part of my router GUI to forward the RPi onto the wider internet instead of my home network. Many thanks to anybody who can help!
See https://docs.syncthing.net/users/faq.html#how-do-i-access-the-web-gui-from-another-computer, and you will need to create a port mapping for port 8384 or whatever port the GUI is on.
