We need a better download page, showcasing the GUI options and guiding the user towards the correct platform etc. I’ve created a very bare bones embryo of this in the repository GitHub - syncthing/downloads: Download page generator, currently running on https://syncthing.net/dl. It needs a bunch of more work though:
Some sort of graphic design. Currently it’s the simplest HTML that could possibly work.
Browser detection code for highlighting the correct download for a given user.
Features like per project screenshots (maybe add this as an URL in the config? maybe auto extract from the project description or README?), per project changelogs, etc.
So there are three possible skillsets here that are individually useful - designer/HTML hacker, Javascript hacker, Go backend hacker. I can provide the latter, if someone wants to fill in on the first two and needs help.
(The projects on that download page and their order are just something I threw together from the top of my mind to get something rolling. Don’t be sad that I didn’t include everything - we should do that once it’s good to go.)
I took a look at your dl page embryo, and hacked a piece of JS to highlight the download links for the “local” platform (the one where the browser is running).
To test it I just copy/pasted the content of
this gist in the JS console of your page.
Tested on Mac(Chrome,Firefox,Safari) & Windows 10 (Chrome,Firefox,Edge,Edge-in-IE-mode).
Feel free to steal, or to ask for more, I’d be happy to help (I’m a developer, not too shabby with web design, not very proficient in Go but you’ve got that covered).
You get the idea, edit suffix and reload to see what other platforms would see.
At this point it only works with reasonably-recent browsers, and requires JavaScript enabled, but it’s always possible to degrade nicely (with more work, also the approach would depend on the backend).
As noted in my first experiment, it’s easy to detect the platform, but hard to correctly detect cpu architecture, so I simply put amd64 above 386… Maybe we can do better.
The layout looks a bit cramped, you should probably space out the buttons a bit more. And you should display the platform in a way that’s easier to read for humans. Also, discovery and relay server should really be hidden somewhere, because they will just confuse new users. And I think you should add links for Synctrayzor, Android, …
These are just some suggestions to help you, I like the general design
Also I think that choosing a version should be de-emphasised. You need to pick the correct platform, but you’ll only choose a version other than the latest if you need to downgrade for some reason.
Added third-party components, with screenshots for the 2 GUI wrappers
User-friendlier: you choose a platform, not a file
Version still choosable, but less in the way, and you get a warning if you select a version that is not the latest
discosrv and relaysrv buried down after all the rest, in a separate section
If you select Windows, an alert box invites you to check out SyncTrayzor
If you select Linux, an alert box informs you about the existence of distribution packages
The design is entirely “delegated” to bootstrap, which @calmh was already using in the beta page, I did nothing to customize it.
Some people will instantly recognize it, and some of those might dislike it.
We can always customize the CSS to make it more unique, but I’m not particularly good at that.
I still have no idea if that sort of thing is still needed, and if so to what degree the user should be guided (I started with merely highlighting relevant links and moving them to the top, then I preselected them “into” a nicer download button, now I give hints about relevant third-party tools… do we need a Clippy-like assistant ? )
At this point I was going to say a lot would depend on the back-end (to provide links directly from GitHub & such, instead of a hardcoded blob of json like I did in my mockup), so it’s nice to know where the sources for this are.
I was also considering a simple function to convert platform names to user-friendly names, and I see there is one in the back-end already.
But this forum topic was created in on March 23, and then some work happened in the “v2” branch of the website repo, latest commit on April 19, with unfortunately no mention here in the forum… So I started from the “very bare-bones embryo” mentioned earlier, completely ignoring the existence of this healthy fetus in a branch of the repo (yeah I’m taking the original analogy and running with it, hehe).
If the new-download-page project still needs help, it would be nice to follow-up here, or leave a note about where the relevant work can be tracked.
