Would be possible to share a folder with Syncthing but the users can’t change the contents, just me? Thanks!
You can use the folder type “Master”. This will ignore all incoming changes. If one of the other nodes changes a file, it will get synced to every node except yours. You will then have a “override changes” button to enforce your version to the other nodes.
Alright, thank you.
