totoba
(totoba)
#1
I started getting this error on two Android devices. I am not using the Android app, I use the 0.14.23 arm builds.
ST does not seem to crash but it just throws this error.
Panic: runtime error: index out of range
goroutine 63 [running]:
panic(0x284bc0, 0x1070a030)
/home/pi/dev/tools/go/src/runtime/panic.go:500 +0x33c
main.watchSTEvents(0x108aa140, 0x108b0000, 0xd, 0xd)
/home/pi/dev/src/github.com/syncthing/syncthing-inotify/syncwatcher.go:920 +0x8d8
created by main.main
/home/pi/dev/src/github.com/syncthing/syncthing-inotify/syncwatcher.go:283 +0x3b4
It’s inotify that is crashing, it’s probably worth opening a bug on their github repo.
Zillode
(Zillode)
#4
Open the issue on syncthing-android. The inotify submodule needs to be updated.
system
(system)
closed
#5
