I am getting this out to sync issue. I have tried pausing the sync and starting it again and restarting the Syncthing on my linux and phone but it did not help either. does knows how to fix this.
What is your filesystem? The files end with ., and those may not be accepted, e.g. if it is NTFS.
yes it is NTFS, but as you can see my other folder camera got synced without issue. I also tried to delete the sync of WhatsApp and tried again but is again got stuck on the same files. In which file system should i backup and how NTFS is affecting this. Also i am backing up from my phone to linux pc.
It seems to me like you must rename files by removing the trailing dot.
Thanks man, it worked.
