Check console logs for clues.
I gave up. I couldn’t take it any longer, so I removed Pictures from Syncthing on all three hosts and re-added it, and a few minutes later all three hosts are reporting “Up To Date”, and the “Garmin” directory got sync’ed.
I am seeing the same issue. My cluster is currently all Linux, but the issue was introduced when a Macbook was temporarily added to the cluster. That Mac is no longer part of the cluster.
I later found that the Macbook’s RAM was going bad, after experiencing repeated corruption of the Mac’s Syncthing index database.
It’s possible that the mac announced some changes that are now nowhere to be found. You should modify the file on some other node.
Thanks, that did the trick. It was tedious since there were a few dozen files.
