To be specific, it does not require a full restart, but it does require the folder to be paused and resumed to trigger.
For reference:
https://github.com/syncthing/syncthing/issues/7371 https://github.com/syncthing/syncthing/issues/7850
For reference:
I see the latest posts are from 2021. Is the “follow symlinks” feature available in the latest ST for Windows, or only in future beta vesions? Thanks
Congrats again for this great project.
PS: I see @calmh mentioned in Option to follow directory junctions / symbolic links? - #134 by calmh that it is implemented, but when I tried to add a symlink to another directory (created with mklink /d ... ...
on Windows) in a Shared folder, the other computer did not sync it.
This is a long thread. Despite the phrasing of the topic, the only thing that is implemented is following junction points. Symlinks are not followed and there are no plans to ever do so.
@calmh Thank you for your answer.
On Windows, I tried with a junction and it works now, if and only if I set <junctionsAsDirs>true</junctionsAsDirs>
Minor drawback: any change in the directory which is linked with a junction is not automatically detected by the FSWatcher. I have to do a “Rescan all” in the GUI each time I want to sync the modifications inside the junctioned-directory to the remote computer.
Is this a known “in-progress” feature, or just a wrong configuration on my side?
Did you restart or pause/unpause the folder? That’s most likely needed, if it works at all. I wouldn’t be surprised if the system library for watching doesn’t automatically handle/follow junctions. And I have no intention to look into making it do so/add workarounds.
After further tests, I confirm that the automatic FS watcher (for new files/file changes) doesn’t look in the junctions directory by default on Windows, as of today (June 2022, ST 1.20.2)
We have to do either:
“Rescan all”
“Pause all” and “Resume all”
I don’t think that’s necessarily the case. I’ve just done a simple test, and Syncthing was able to automatically detect new files inside the junction with no issues.
Where does your junction point at specifically? Just in case it’s a drive root or somewhere similar, there’s a known issue about the watcher not working there.
Scrap the above. It only worked initially after creating the junction itself (and thus it scanned its subfolders too), but it doesn’t work anymore when doing file manipulations inside the junction.
Please do something about this.
This not only causes the symlinks to stop syncthing, but all the rest of files.
It shall either ignore symlinks all together, or just code them into a special file with metadata. Nothing else.
But pausing just everything, it’s a big no no. The user may not realize that syncthing stopped working.
You mean like… a symlink?
This shouldn’t happen. Can you post screenshots of the affected side?
Okay, now I see why.
Syncthing is also unable to sync files if their names contain :
Which is what is happening to me while building Arch Linux packages that contains not only pkgver
but epoch
, for example:
c++utilities-100:5.23.0-4-x86_64.pkg.tar.zst
Its nothing todo with syncthing, but with the filesystem that it’s being synced into. Thats an invalid character for some filesystems.
I didn’t read the whole thread, sorry if the following was already said: Here is how I do not create many folder shares when it comes to sync as many directories. Just create a single folder share at the highest level of tree to be synch’d (e.g. Documents, or even user home/profile, or even the whole drive c:) and use (don’t)ignore patterns, e.g. with whole / shared
!/home/user1/Documents
!/home/user1/Music
!/home/user2/Documents
!/etc/hosts
//DO NOT FORGET THE ONE BELOW!!!
