OpenBSD test debugging
(Edd Barrett) #41
OK, one more item before I agree with Audrius and suggest we just disable these tests on OpenBSD (and maybe delete the useless test).
Wouldn’t it be better to have each test use mkstemp() to make a uniquely named temp dir, then tests can’t clash. And if teardown fails, then we don’t care, as /tmp is cleaned on each reboot (sometimes before).
Thanks guys!
(Simon) #42
That’s exactly what we do in most cases. As we didn’t in most cases in the past, we had tests fail if their cleanup fails.
(Edd Barrett) #43
So we could just allow teardown to fail and be done with it?
(Simon) #44
We can and now do on master, along with all the rest of the changes resulting from this thread (not in 1.1.0-rc.1 unfortunately).
Thanks a lot for your time!
(Edd Barrett) #45
Excellent! And thank you for your time!
I’ll test master at some point :slight_smile:
