I have had a syncthing setup running for several months now without much issue (other than finding some old clients weren’t updating). I have confirmed that all are running version 1.12.0, but I have one device (a Windows 10 laptop - work issued) that will connect and usually will sync successfully when it first boots up (or when I close syncthing and reconnect it), but after that I get a bunch of messages about “connection refused”, “context deadline exceeded”, “handshake did not complete in time” and “i/o timeout”.
I have to assume that either something has changed in our corporate network that is blocking this, or something in syncthing has changed in some of the more recent versions?
I can provide logs from both ends if that will help. I just want to know if there is a configuration that I can adjust, or if I am just out of luck using this on my work PC. I just use it for syncing some folders between machines for 3D printer usage, some coding work, etc.
One additional bit of detail - the main device is a raspbery pi 4 with a USB attached SSD (boot and data drive - no SD card), while the other devices are mostly Windows 10 PCs and laptops. I also have an Ubuntu client and a Mac client in the mix. Those all work fine for me. Just the work issued laptop is the problematic device.
I suspect firewall might be part of it, but not sure why it would work initially and then stop. I do have to connect to VPN for some things, but after I posted originally, I thought that I would try disconnecting the VPN and then restarting Syncthing on the laptop, and left for about 2 hours. When I came back, I checked the gui on the Pi and I see the same error messages under the disconnected work laptop.
I have no idea, but there is nothing special here, just refused/broken connections, which are most likely due to firewall. Why it happens sometime later I don’t know.
